Connection Fix
Fix for connection issues
Older OpenVPN builds will have connection issues with newer client releases. To fix this issue run the command below to install the newer OpenVPN package from the Pritunl repository. A TCP server can also be used as a workaround to fix some of the issues.
RHEL, Oracle Linux, Alma Linux, AmazonLinux
The pritunl-openvpn package is available on all the Pritunl RHEL repositories and will provide the latest version of OpenVPN.
sudo yum swap openvpn pritunl-openvpnsudo yum --allowerasing install pritunl-openvpnThis can be reverted by running the command below.
sudo yum --allowerasing install openvpnUbuntu
For Ubuntu use the OpenVPN Debian/Ubuntu repositories by running the commands below.
sudo tee /etc/apt/sources.list.d/openvpn.list << EOF
deb [ signed-by=/usr/share/keyrings/openvpn-repo.gpg ] https://build.openvpn.net/debian/openvpn/stable focal main
curl -fsSL https://swupdate.openvpn.net/repos/repo-public.gpg | sudo gpg -o /usr/share/keyrings/openvpn-repo.gpg --dearmor --yes
sudo apt update
sudo apt --assume-yes install openvpnsudo tee /etc/apt/sources.list.d/openvpn.list << EOF
deb [ signed-by=/usr/share/keyrings/openvpn-repo.gpg ] https://build.openvpn.net/debian/openvpn/stable jammy main
sudo apt update
deb [ signed-by=/usr/share/keyrings/openvpn-repo.gpg ] https://build.openvpn.net/debian/openvpn/stable noble main
sudo apt update
deb [ signed-by=/usr/share/keyrings/openvpn-repo.gpg ] https://build.openvpn.net/debian/openvpn/stable buster main
sudo apt update
deb [ signed-by=/usr/share/keyrings/openvpn-repo.gpg ] https://build.openvpn.net/debian/openvpn/stable bullseye main
sudo apt update
deb [ signed-by=/usr/share/keyrings/openvpn-repo.gpg ] https://build.openvpn.net/debian/openvpn/stable bookworm main
sudo apt update
sudo apt --assume-yes install openvpnUpdated about 1 year ago
