> For the complete documentation index, see [llms.txt](https://docs.pritunl.com/kb/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.pritunl.com/kb/zero/general/pritunl-zero-docker.md).
# Docker Image
Pritunl Zero Docker image
Pritunl Zero can be run from a Docker container using the command below. The `NODE_ID` is used to identify the node in the cluster, it must be unique for each running Docker container.
```shell
docker run --rm \
	--name pritunl-zero \
	-p 80:80 \
	-p 443:443 \
	-e MONGO_URI="mongodb://mongo.example.domain:27017/pritunl-zero" \
	-e NODE_ID="5b8e11e4610f990034635e98" \
	docker.io/pritunl/pritunl-zero
# Agent Instructions
If you need additional information that is not directly available in this page, you can query the documentation dynamically by asking a question.
Perform an HTTP GET request on the current page URL with the `ask` query parameter, and the optional `goal` query parameter:
GET https://docs.pritunl.com/kb/zero/general/pritunl-zero-docker.md?ask=<question>&goal=<endgoal>
`goal` is optional and describes the broader end goal you are ultimately trying to accomplish on behalf of the user. GitBook uses it to tailor the answer towards what is most useful for that goal.
