> For the complete documentation index, see [llms.txt](https://docs.pritunl.com/kb/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.pritunl.com/kb/zero/general/pritunl-zero-docker.md).
# Docker Image
Pritunl Zero Docker image
Pritunl Zero can be run from a Docker container using the command below. The `NODE_ID` is used to identify the node in the cluster, it must be unique for each running Docker container.
```shell
docker run --rm \
	--name pritunl-zero \
	-p 80:80 \
	-p 443:443 \
	-e MONGO_URI="mongodb://mongo.example.domain:27017/pritunl-zero" \
	-e NODE_ID="5b8e11e4610f990034635e98" \
	docker.io/pritunl/pritunl-zero
# Agent Instructions
If you need additional information that is not directly available in this page, you can query the documentation by asking a question.
Perform an HTTP GET request on the following URL with the `ask` and `goal` query parameters:
GET https://docs.pritunl.com/kb/zero/general/pritunl-zero-docker.md?ask=<question>&goal=<user_goal>
`goal` is what the user is ultimately trying to achieve, the reason they need the answer. Sharing it helps GitBook give you a better, more relevant answer. A goal is most helpful when it describes the outcome the user wants rather than restating the question. For example, with `ask=how do I create an API token`, a goal like `automate deployments from our CI pipeline` lets GitBook tailor the answer to that use case.
