> For the complete documentation index, see [llms.txt](https://docs.pritunl.com/kb/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.pritunl.com/kb/zero/general/gitlab-demo.md).
# GitLab Demo
Pritunl Zero GitLab demo
This demo will demonstrate the work flow for a user accessing Gitlab with Pritunl Zero. The demo is not part of configuring the server and can be skipped. The demo will be run in a temporary Docker container. It is recommend to only run the demo in a Docker container as the Pritunl SSH client will need to be installed and configured.
First go to [**gitlab.pritunl.com**](https://gitlab.pritunl.com) and login with the username and password `gitlab`. Optionally you can create an account, the email address is not verified. Then run the commands below to clone the demo repository in a temporary Docker container.
```shell
# Pull oracle linux 7
docker pull oraclelinux:7
# Start oracle linux container
docker run --rm -ti --entrypoint /bin/bash oraclelinux:7
# Add pritunl repository (copy all lines together)
tee /etc/yum.repos.d/pritunl.repo << EOF
[pritunl]
name=Pritunl Repository
baseurl=https://repo.pritunl.com/stable/yum/oraclelinux/7/
gpgcheck=1
enabled=1
gpg --keyserver hkp://keyserver.ubuntu.com --recv-keys 7568D9BB55FF9E5287D586017AE645C0CF8E292A
gpg --armor --export 7568D9BB55FF9E5287D586017AE645C0CF8E292A > key.tmp
rpm --import key.tmp; rm -f key.tmp
# Install git and pritunl-ssh
yum -y install pritunl-ssh git
# Add the demo SSH key
mkdir ~/.ssh
tee ~/.ssh/id_rsa << EOF
-----BEGIN RSA PRIVATE KEY-----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-----END RSA PRIVATE KEY-----
chmod 600 ~/.ssh/id_rsa
tee ~/.ssh/id_rsa.pub << EOF
ssh-rsa AAAAB3NzaC1yc2EAAAADAQABAAABAQDEpZGFVmOftnUPDmkuRukkddKblmfSieg5h4fp7k/U7w78ynyq4JjihBm9/kNAtEyHkRwcZzrPmu5RuFNDI3llBDrul2bhBvHq9oObk38HdS8eBTPO0jCtZ67eG+86JN2aP7rOsRoihhBkBJ2pJC7eSyMrbHeedckP19lBNsN3s5QLWa+yZDxNF9i45B+rLClbLhRutQr1JxWT2qsZ7mPseVjEQXuKecZVpZrpjxiJkct7SMsoWkxI7/24ZnwCb4bty/HijeyEcl9SWQ3GylmR+YI7z1aSQCGIviDvlClvynbJNLV8UyPBRBJ32NYS17p4r2aX81VjNTQk27r8Jvp1 root@d97b54c18226
# Configure pritunl-ssh using the values below
pritunl-ssh
# Enter Pritunl Zero user hostname: zero-user.pritunl.com
# Enter key number or full path to key: 1
# Use cmd or ctrl double click to open the link
# Login with username and password "gitlab" and approve the ssh key
# Clone the demo repository
git clone git@ssh.gitlab.pritunl.com:demo/test.git
# Agent Instructions
If you need additional information that is not directly available in this page, you can query the documentation by asking a question.
Perform an HTTP GET request on the following URL with the `ask` and `goal` query parameters:
GET https://docs.pritunl.com/kb/zero/general/gitlab-demo.md?ask=<question>&goal=<user_goal>
`goal` is what the user is ultimately trying to achieve, the reason they need the answer. Sharing it helps GitBook give you a better, more relevant answer. A goal is most helpful when it describes the outcome the user wants rather than restating the question. For example, with `ask=how do I create an API token`, a goal like `automate deployments from our CI pipeline` lets GitBook tailor the answer to that use case.
